Hey guys, I have a Benchmade 942 that I've been trying to sharpen. It was an older model that came with a 154cm blade. I sent it in for a new blade from Benchmade, and it came back with a s30v blade that wasn't very sharp. I've tried touching it up on the Spyderco sharpmaker, on the 40 degree side, but could still never really get it sharp. So, last night I starting looking around online, and I saw a post where someone mentioned that they had the same problem and called Benchmade, who told them that they grind their knives at 30 degree. So, I decided to give it another go on the sharpmaker. This time I did the sharpie on the blade trick to tell if I'm getting the right angle. Well, after a few swipes on one side, the marker was removed all the way down to the edge, so I assume that this side is at the proper 15 degree bevel. On the other side, I sharpened the heck out of it, and just can't seem the get it to where the maker is removed all the way down to the edge. I assume that means the this side is still not down to 15 degrees yet. The thing that bothers me a little is that the bevel on the non 15 degree side is starting to look wider (from spine to edge) that that of the 15 degree side. Is this normal? I'm deciding between sending it off to Razor's Edge or just keeping at it myself.
