Help: Taken my Benchmade rift apart and cant put it back.
Hi Everyone.
This thing is more fiddly than I thought.
Do you know of a video or pictures of how to put it back together?
Any axis lock bwnchmade will do.
Thanks
What are you having a problem with? I'm sure we can explain what needs to be done as they aren't that complicated. Sometimes getting the blade and washers lined up to slide the pivot bolt through can be the hardest part.
Thanks,
Well I first put the omega spring in the lock on the liner then put the g10 scale
Then slide the pivot volt
Then Do I put the back spacer pins in place and put the other liner?
It can be put back together any number of ways as far as the order the parts are put back and the strategy you use to get it back together.
I would probably put the G10, liner, spring of one side together then put the screws through the hole and then put the spacers on them, and the backstop pin. Then put the other liner on and get the backstop pin in place and the spacers pinched in place and the lock bar going through and the spring attached. Then get the other liner lined up and the screws put into place and start to tighten everything up. I would probably get the blade and washers back in and the pivot snugged up before I did the final tightening of the screws.
It probably would help to have an extra 2 or 3 hands but eventually you will get it.
FlaMtnBkr, THANK YOU very much man. I just got it back together using ur instructions.
Bless you
