- Oct 30, 2002
Well, I'm a little thick when it comes to wiring, so I always make sure and ask a million questions before any juice ever runs through it.
I'm in the process of setting up a PID control box for my forge. I'm basing off of the schematics posted by Stacy and JT a while back in these threads:
http://www.bladeforums.com/forums/showthread.php?t=600318
http://www.bladeforums.com/forums/showthread.php?t=523845
Anyway, Here's where I'm at, and I have a few questions. I'm in the planning and layout stage right now. The gas solenoid I'm using has two identical wires coming out of it. Obviously one will be receiving the switched power form the SSR. Does the other on connect to the neutral? Also, my PID has no ground labeled on it. It does have two inputs for the AC, but there is no +/- or anything like that. So I'm assuming the hot and the neutral attach there. Since there is no labeled ground, should I ground to an unused screw (#6)? Here's the PID wiring diagram:
Here's a really bad schematic of my wiring plan, keeping colors of the power cords the same (black=hot, white=neutral, green=ground):
This is off the top of my head (from my poor memory) of what I've layed out at the shop, so there is likely some mistakes. Please call them out as you see them!! Any guidance here is appreciated!! Thanks!
--nathan
--nathan
