- Nov 27, 2013
I’ve been spending the last hour search the history on here for threads that I could have sworn were here at one time, but I’m not finding now. I’ve tried searching via Stacy’s “Bladeforums custom search engine” and the in forum search. No luck. One was either made by Devin Thomas or had his findings in it regarding heat treating methods if only having one heat treat oven. I also looked in the HT section and there doesn’t seem to be many stainless recipes in there.
Could you guys give me some feedback on my CPM-3v and AEB-L.
****My AEB-L recipe****
Place foil wrapped blade in oven at 1725f and soak for 20mins
Plate quench
Increase oven temp to 1965f. Once oven reaches temp, place blade in and soak for 10mins
Plate quench
Cryo in LN for 12 hrs
Temper at 375f for 2hrs two times for 62-63hrc/ temper at 350f for 63hrc
****My CPM-3V recipe****
Pre-heat foil-wrapped blades in oven at 1250f and soak for 10mins
Raise oven to 1550 and soak for 10mins
Raise oven to 1950 and soak for 30mins
Plate quench
Cryo in LN for 12hrs
Temper at 400f for 2hrs three times. 60-61hrc
Now, my main concern is with the 3v heat treat. Soaking at the three different temps would be leaving the blade in the oven for quite a long time. I think I remember reading somewhere that it wasn’t needed to do the preheat with 3v if you only have one oven. Is that correct? Would it be best to just go straight to 1550f and soak for 10mins and then ramp(while leaving the blade in during the ramp) to 1950f and soak for 30mins?
I’m using a Evenheat 22.5 KO with a TAP controller. I had been setting the starting temps 100f higher than the needed temp because when I open the door and put in cold blades, the temp drops 100f by the time I get the door shut. Then I start the firing schedule at the normal temp. For instance 1725f for AEB-L. Does that make sense?
Also, when having a knife in for its first temp soak, say at 1550f for 3v. I’ve just been leaving the blade in while it ramps up to the final temp of 1950f. Sometimes that takes up to 30mins or so. Then I let it soak at temp for the 30mins, at 1950f, which the recipe calls for. Is that how you guys do it?
Any critique you guys could give me on these recipients would be greatly appreciated.
Plate quench
Plate quench
Plate quench
