 - Jul 21, 2020
I just got a seconds M4 Yojumbo. It came with the blade horribly off-center. It was actually touching the right side scale. I tried the paper wedge trick and now it's just favoring the right side but not rubbing which I can deal with (I guess). The problem is that I still hear a rubbing sound about 75% through the actuation of the blade. I've looked at this thing under a light slowly moving the blade back and forth and cannot see where the sound might be coming from. It's definitely not near the tip of the blade where it was originally rubbing the scale. Is this normal for this knife? Should I even be concerned if I don't see the blade touching the scales at any point?
Also, after doing the wedge thing I had to loosen the pivot enough for smooth action but there is a little lateral blade play when locked out. If I tighten it gets more off center and the action gets so tight. Am I just screwed with this or should I try the wedge trick again?
Thanks guys I've never had to deal with this before.
