- Oct 7, 2016
Some time ago I got a little Arkansas stone at a flea market.
The stone was to be used to sharpen flat-lead mechanical pencils. They tell me that in the past it was not uncommon for deliners from large companies to sharpen their pencils on these stones.
I say flat flat leads because there were leads for this type of mechanical pencil in the same position. I attach a photo of a pencil of this type from the Internet.
The stone, even if it is small, looks of a much higher quality than the current ones.If it is seen in the light, a lot of small glitters are observed.
I have used the stone once to use it with soap (I usually use oil but this time I use soap because in principle it was only to test it)
Has left a spectacular sharpening
The question I have is why the other translucent stone that I have and the ones that I have seen tend to have more silver tones.
It should be noted that the box in which it is mounted is made of extremely aromatic wood.
I leave you some photos.
He will not let me put more photos, I will try in an answer.
I would appreciate any kind of information.
I also apologize if it is not well understood.
