- Aug 2, 2010
Hey guys, I was reading up on a recent thread just a few days ago on how to properly anneal hypereutectoid steels like 1095 using a gas forge. (It was about Ash annealing Hitachi white steel) Stacy gave some great instructions that I just tested out and they work great, the steel is much easier to work with than when it used to just heat it up then bury it in vermiculite. It was basically heating to about 1250F and letting cool to black then quenching in water and then repeat a few more times.
Well anyway I have been using quite a bit of 5160 steel from leaf springs and have had a helluva time trying to drill holes in it after putting in vermiculite. I also have a legnth of Aldos 1075 that will be seeing a lot of forging so I was wondering if you could help me out with a good process for Normalizing/thermocycling and then annealing, and then the best way to HT or Austinize n temper both of them. Also, since 1080 and 1084 or basically eutectiod steel, would there be a diff process for annealing those? I already know how to HT those steels but I'm looking for help with mainly 5160 and 1075, and if by any chance you could, I would like the same info for 52100, that would be great!!
Thanks for any help in advance and I hope I'm not askin for too much. Just a step by step for each steel would be great such as
-Forge at: X
-Normalize by doing X, X number of times
-Anneal by doin X, etc..
-Harden by Austinizing at X for X minutes
and temper and X, X times (I know this is obviously going to be different for what type of knife your making and it's purpose, but just a general temp for regular EDC type blades would be great.
Thanks a lot!!
-Paul
(Some of my knives etc.) www.youtube.com/Lsubslimed
-Forge at: X
Thanks a lot!!
-Paul
