Let's see if I can articulate my question: I see more bevel closer to the tip of my blades than on the flats. Most of my blades are flat or full flat grind. Assume the bevel angle is constant, but I think it is because the blade is thicker at the back than the edge. When I see pictures of knifes most of them show a bevel that is the same from tip to tail.
Is this a problem for a general purpose outdoors bushcrafting or camping knife? Weaker tip prone to damage? I don't slice with the tip, I slice with the flat and curve, and on a bigger knife might use it to split smaller wood if lacking a wedge or hatchet. (And as much as I like to get out, I don't very much, so do not have enough hands-on experience...)
Or is this an aesthetic issue that indicates a noob or careless technique? Currently I'm using EdgePro. I had a Lansky-type which did change the angle towards the tip, but with the EP I keep the stone in the same area and move the knife according to instruction videos.
The top blade is a RAT-7, hopefully you can see the new bevel edge that would be cut, then the blue marker showing the original bevel. The bottom blade shows the issue I'm talking about very well. The blade is the same thickness across the back. The flat edge is very thin and shows almost no bevel length, but the tip on has a very long bevel length.
[/URL][/IMG]
[/URL][/IMG]
