So, I feel kind of like an idiot... I'm making a liner lock and hoping I can get it to be my first successful solo build for a folder. But, I need some help with my countersinks. I need to use one to help deburr drilled holes and have run into some "challenges". I had a 1/4" diameter, single flute, carbide countersink already on hand. But, that single flute ends up making the liner move around and around and around.... Plus, it seems like the smaller diameter can end up giving me some issues as I start running out of cutting flute, if that makes sense.
SO, I decided to get online and ordered a 6 flute, 1/2" diameter, carbide countersink. I was all excited because it finally came today and immediately went into the garage to give it a go. I grabbed a scrap piece of liner (from past failures...) and it became apparent very quickly that things weren't going to work out. The point of the countersink is, well, not there. This particular countersink is flattened off at the point instead of going all the way to a point. So, my smaller screw holes can't get chamfered. I even tried it on my 3/32" holes and those holes are just a fuzz too small for the flutes to get in there. Needless to say, I was pretty frustrated that I didn't realize that problem before ordering.
I borrowed a cheaper HSS one from my dad and gave it a whirl. It countersinks the Ti liners, but actually leaves a small burr on the top that I can catch my fingernail on. I feel like it cuts in some of the countersink, but just isn't sharp enough to not leave a burr that I'll still have to take to my granite plate and sandpaper....
Soooo, what do you guys use? Am I missing something with the single flute one? I feel like that wobbling actually opens the hole up just a tad. Should I just find another 6 flute carbide one with a point instead of that flat? What do you use and how do you like it? Thanks for any suggestions.
Jeremy
First time posting pics from imgur….hoping it works right...
Jeremy
