Help With Dating Case Tang Stamp
Sibyrnes
It looks like the tang used in the 80’s but it has no dots. They changed pattern in 1990. Any ideas?
So that's a dot? I could not see it on the knife itself, but it's visible in the photo! Thanks.
No prob!
It may just be worn down or wasn't imprinted real deep if you shine a light at it and hold it at different angles you may be able to see it better.
Hope it’s okay to jump in this tread. I’m having trouble with this stamp too. According to the link R Reconmarui posted the USA should have a lightning bolt S. What do you think?1368A203-F7ED-4A0E-98FC-BE911312477F.jpeg
Hope it’s okay to jump in this tread. I’m having trouble with this stamp too. According to the link R Reconmarui posted the USA should have a lightning bolt S. What do you think?View attachment 2252500
Look at the 1993 to 1999 section and hit the "see all button" 5 dots should make this 1995. This is 2 spots to the right of where OP's tang stamp was on that link. This has the fancy C instead of OP's regular text on his website (I'm sure there is a proper name other than fancy C)
My problem isn't the date, but the stamp itself. My USA is rounded whereas the link you posted is a "lightning bolt "
EDIT: After some searching I found the answer. The USA with the lightning bolt S is for those knives with stainless steel. The rounded S (like mine) indicates CV.
