- Sep 12, 2007
Some time ago I mentioned I had issues finishing Vanadis 4E - I was getting blotchy/spotty finish above 400 grit.
I ordered some cheap diamond pastes to try out with the hope that the finish will improve.
They arrived and I tried the coarsest one I have - W20 (~600 grit?) and I can say that it does cut well and the finish really did improve, and I only just started to learn to work with it. But I have some questions.
I made this lap from mild steel. After doing two blades there is already some wear there, the machining marks are gone in the center. Should I use something softer like brass/aluminum so that the paste embeds itself in the lap more readily? Or more grooves for the swarf? Or is it expected that the lap will have to be flattened very often (which in a way makes sense, I just did not expect it to happen so fast)?
If you use pastes in this way, how much would you use, or what is the consumption rate roughly? For now it seems to me I should be able to get maybe multiple blades from one small 5g tube (and considering the price that seems to be a good deal) but I am wondering how much of it are you guys using.
I also have some loose diamond powder and will try to make my own compound.
Thanks.
Thanks.
