- Jun 1, 2019
Hello BF, I have read a ton on here and feel like I have tried multiple method but still feel like I am having issues.
I have the personalizer plus. I have stencils from Ernie.
I forget what solution I use, but I remember buying it off of recommendations from several members on here. So I know its good.
I set the personalizer plus to 4 and I do light taps on etching. About 1 second each, and do about 25 of those. Then I switch it to mark and do the same thing. When I remove the stencil I don't have a dark marking. The etch looks good and deep but the etching is weak.
I am also using some gator clips with some cotton pad rolled up, I am not using the little applicator that came with the machine (Saw some makers doing this method online).
So my question, If I just mark it only, will that rub off? Whats the advantage of etching first then marking?
Anything else you recommend that I am doing wrong? Is the #4 setting not accurate?
Thanks a lot!
Thanks a lot!
