Help with flattening Shapton Glass/Gokumyo 20K stones for Edge Pro... DMT 95?
OhioApexing
Sharpener
I'm looking to pick up a set of Shapton Glass stones for the Edge Pro, ranging from #220-#16k. I'll probably grab a #20k Suehiro to add to the fun, because, well, I like sharp things and hate money.
Anyhow, what will I need to lap/flatten these stones? Will the DMT 95 lapping plate be sufficient for the whole range? It is my understanding that higher/lower grits require differently sized abrasives to lap properly. If that doesn't work, what will?
Although I hate money, I don't hate it enough to drop $300+ on the Shapton lapping plate.
EDIT: If not the 95 DMT, what about the 120?
View attachment 1033495 Shapton recommends The Diamond Glass Lapping Plate for stones 30 micron/500 grit or finer. A coarser lap is recommended for the 120, 220, and 320 stones. So you probably need at least 2 laps to cover your spread.
Yes, it is an Aluminum block with a glued on Diamond strip. The storage drawers are from a Festool cabinet.
I use a DMT 95 flattening plate to lap my stones and a DMT Fine 4x1 plate to condition the higher grits, including my Shapton Glass and Gokumyo 20k, and I haven't found any reason to use any other method. The 95 is an excellent tool
The bottom plate is coarse looking. Is that the 140 grit Atoma? DM
Atomas always look coarse because of the "diamond dots" - the diamonds are applied to the plates in small circular clusters, leaving space in between for swarf etc. to escape. The 140 of course, is pretty coarse.
