- Feb 23, 2017
So this is my friend's forge. He's not forum friendly; so I'm posting for him.
He runs through a BBQ size propane tank in about an hour.
Originally he was not using a regulator and had to turn up the propane all the way up to get welding heat. Now with a regulator he can't seem to get welding temps.
If you look at the pics you can see his setup. He doesn't know what blower it is, but it puts out a good amount of air.
The forge is 2" of kaowool, then 1/4" fire clay, and some unknown refractory cement (I think it's like satanite). Before adding the refractory cement and no regulator he couldn't get welding temps. The interior size is 21" x 6" x 7". He's using 2" pipe for the burners with a .068 orifice size.
Also when starting the forge if he has the air up too much or if the propane is up too much then it back burns into his burners.
The dragon's breath comes out about 5'.
What he's concerned about is the dragon's breath coming out so much, hard to get welding heat and running through too much propane.
Any help would be appreciated.
https://www.dropbox.com/s/1ssn3aexjao8szi/IMG_5704.JPG?dl=0
https://www.dropbox.com/s/iodle7aoudtd2ip/IMG_5913.JPG?dl=0
https://www.dropbox.com/s/31npup1zftwxewx/IMG_5914.JPG?dl=0
https://www.dropbox.com/s/5r62du605kznv5t/IMG_5915.JPG?dl=0
https://www.dropbox.com/s/wamqc5xc6vghi8k/IMG_5916.JPG?dl=0
https://www.dropbox.com/s/iwmekyos70r1noe/IMG_5928.JPG?dl=0
https://www.dropbox.com/s/h21hjz0iejp1i4g/IMG_5929.JPG?dl=0
https://www.dropbox.com/s/apxcunv77kg53vo/IMG_5930.JPG?dl=0
https://www.dropbox.com/s/y7uwymx4sf85nke/IMG_5744.MOV?dl=0
