I'm trying to make a transition from a filing jig to a 1x30 grinder, so I made this jig.
It will be a jig only used for this pattern. So I would have to make another one for different style blades.
Holding a folder blade seems to be a little more troublesome.
Here is a blade I used the hand filing jig on. I got it the way I want it and chucked it up on my new grinding jig. This is so I can try to get an exact replica.
So the black line is the end of my flat grind.
I want to set this parallel to the bottom of my jig correct?
The black dot below the blade is where I believe I will put a stop pin for the blade to rest on.
Now the plunge line on my knives are set to a slight angle.
Can this not happen while grinding and keeping my end of grind line parallel ?
Any tips????
Any tips????
