here is my attempt at my first knife which failed due to using mild steel, then i side tracked to making a knife from a 7mm thick file which was a 3 hour grinding process ... I'm posting pics as i go...
so to anneal a file i build a small 2 brick forge and inserted 2 propane burners with no luck
I can not get the steel to turn color even after 20 min..
all pics can be seen in the original post....
WHAT am i doing wrong for heat treating?
do i just need more heat?
