Hello folks,
I'm creating this thread since I will probably need to ask some questions now and then. Also could be interesting to document the progress of my work and motivate me to finish this.
I'm slowly (as I'm progressing with my CAD skills) refining the design of my first frame lock.
I want to do first prototype with a blade from N690 steel, presentation side scale from 4mm thick carbon, frame lock side scale from some spring steel since its just first prototype and I don't want to use titanium yet. The knife will use bronze washers and will be cut from the slabs using water jet (to ensure better accuracy that I would achieve with using just my hand, also I lack any propper tooling) from which I will continue to build the final knife. Also, I want to use my 3D printer for the basic alignment, mechanical and ergonomic issues prevention which should help me to get the first steel product hopefully minimize any design issues that otherwise would emerge.
and the first question is:
Q1) Can I use the N695 steel for frame lock? I know that 4mm is too thick so I will have a friend that has a mill/lathe at work to remove some material. If I can use the N695 for frame lock, how much should I mill out from the bend location and is the best hardness to heat treat it to.
Thanks and have a nice day
