Help with my Large Sebenza 21
I made the perfect newbie mistake. My large Sebenza 21 is on its way from BHQ and I ordered a sheath from Al aka pocketknifesheaths here on BF. See the thread here:
http://www.bladeforums.com/forums/showthread.php/1243489-Pocket-Knife-Sheaths-Holiday-Deal
And so he needs the dimensions when the Sebenza is closed. Length x width x thickness.
I found this on the web: length = 4.71"
Can someone confirm and also provide the width and thickness?
Many thanks!
Dimensions from Lrg Micarta Insingo, which I think is basically the same;
4.8 OAL
1.99 (includes blade to back of scales)
.45 thick (not including inlays or pan-head type screws that are proud of the surface)
Let me know if this works or you need any other measurements.
30mm wide at the widest point
14mm thick without clip and with micarta inlays
I hope this helps
Yep..My bad. Should pay closer attention to writing numbers before having my coffee...Width is 1.199 with the blade, ~1.16 without the blade.
