vwb563
- Jun 29, 2007
Hey guys I found this knife in my fathers collection that I inherited and was wondering if you all could help me with authentication and dating it. What’s y’all’s opinion on this one?
I think he might be referencing the tang stamp but not sure.Dont see what as a design?
Its real and its a peanut. Take care of it. Great little knife.I think he might be referencing the tang stamp but not sure.
Yessir, a tang stamp.I think he might be referencing the tang stamp but not sure.
I think you’re correct. It’s bigger than a peanut.It looks more like the 87 pattern medium jack than a peanut, pattern 20.
I don’t see an “exact”matching tang stamp from your chart. Is that normal?To my knowledge, and from checking the only Case chart I have, I don’t see that as a design. I’m limited on reference material regarding tang stamps on specialty runs by them as well. Good luck in your search.
It feels more like celluloid than plastic.I stand corrected. I learned something just now. Celluloid was used from the 20s until ‘45 when plastic composition was first used and Delrin was first used in the early-mid 60s. Apologies.
According to my research, Case first used Delrin in 1967, on the then new Sod buster pattern.Delrin wasn’t invented until 1952, so it could fall into the era after that was introduced as a scale material.
I'm pretty sure Case has used yellow 'composition' handles as far back as the 'Tested' era (1920-1940). That material wasn't actually Delrin, which Case first used in 1967 on the black-handled Sod Buster (pattern 2138). 'Delrin' specifically, as named and trademarked by DuPont, wasn't invented until sometime in the 1950s.
David
Case first used Delrin on the 2138 Sod Buster (black) at the pattern's debut in 1967. Not sure if any others were using it then - but I imagine it caught on pretty quick with other makers around the same time frame.
In the pic below, a pair of my black soddies, 39 years apart. One is a 1970 model and the other from 2009. I always think of the Case Sod Buster by default, when I think of Delrin.
