- Apr 20, 2016
I have read a thread on here about regrinding a primary grind to thin out a blade and correct poor factory grinds. For the life of me I can't find it now that I need it. I have a knife that came with an awful factory grind. Uneven primary and secondary grinds. I wasn't surprised as it was a cheap knife that I intended to mod anyway. Having said that, I've done my mods I wanted. I was scared to mess with the primary grind so I just sharpened the knife. I'm not satisfied with it so I'm looking to try thinning, and hopefully correcting the primary grind.
The tip isn't bent, it's​ just the angle of the picture. But if you look close you can see how uneven the grind is.
I'm​ fairly new to freehand sharpening. I have a Norton combo Crystolon stone. Can I do the thinning by sharpening the knife like I normally would, just on the primary grind? Also, is the coarse side of my Norton the best bet or would I be better off with sandpaper on glass or a file even? I hope I have explained this clearly!
Sent from my XT1585 using Tapatalk
