- Nov 29, 2007
Hello all,
I picked up this small Sebenza the other day at a local pawn shop. I was hoping someone could help identify the date of production, blade material, or provide info on the handle graphic. I disassembled it and there are no stampings inside the scales, nor on the blade. There were two copper washers of the same size on the blade pivot. The top scale appears to be polished, either intentionally or from years of use. The thumbstud has 4 cut ridges that only span about 90 degrees of the circumference. The other 270 degrees is smooth. The overall length is 6 15/16". Thanks in advance,
