How To Help! Zwilling J.A. Henckels AG Lockback Mechanism
I have a folding lock back knife that I know nothing about. I am helping a friend try and get this thing closed....neither of us are really knife people.Link to images
It was given to him as a gift, purchased in Kuwait in 05 but it says it was manufactured in Solingen Germany. The brand is Zwilling J.A. Henckels and the model number appears to be 55665-000. It says TWIN Lift on it.
I have searched high and low with Google, YouTube, and Chatgpt to try and find a video or manual depicting how this is "supposed" to close. It seems to be either too rare or obscure not sure. It is extremely sharp. Friend opened it, got it locked out and now neither of us can figure out how to get it functional. I finally managed to take it apart and can see it maybe is some kind of hidden bolster mechanism? It seems like there is just too much pressure on the mechanism or I am just not understanding how it is supposed to function. Seems like sort of a leaf spring but the cam where it pivots is too tight or something?
Not sure...please help.
It appears as though the entire bolster is meant to arc back to lift the lock, based on those images.
"Its locking system uses a lift-lock system, which is activated by moving the titanium bolster upwards. The bolster is fitted with a rubber insert for better grip, thus unlocking the blade so it can be closed."
ARMAS BLANCAS 66
Desde que tengo memoria he convivido y disfrutado de las armas blancas, considerándolas como útiles herramientas de corte de uso cotidiano. En este blog mostrare navajas y cuchillos de mi colección, así como otras piezas y artículos interesantes sobre cuchillería.
(Mover a...)
viernes, 16 de mayo de 2014
- ZWILLING TWIN LIFT 55665-000
...la historia de la casa ZWILLING J.A.HENCKELS comienza el 13 de junio del
año 1731 (bajo el signo de Géminis), ese fue el día que el fabricante de cuchilleria
Peter Henckels de Solingen registro el símbolo "Twin" como su marca comercial
dentro del Gremio Cuchillero de Solingen. Este símbolo, que ahora es conocido en
todo el mundo, es una de las marcas más antiguas del mundo. El nombre actual de
ZWILLING J.A. HENCKELS se lo dio a la Compañía un descendiente de Peter
Henckels, Johann Abraham Henckels. En la actualidad los productos de esta marca
son reconocidos a nivel mundial como símbolo de la más alta calidad posible...
Tras esta pequeña introducción sobre la casa ZWILLING J.A. HENCKELS, casa que se
especializa en cuchilleria y menaje de cocina, quisiera mostrar una pieza no muy usual en
los catálogos de esta empresa, se trata de la navaja diseñada por el artista Julian Brown y
denominada ZWILLING TWIN LIFT 55665-000.
Esta navaja monta hoja lisa en acero 440C y terminacion satinada, su mango se compone
de liners de acero sobre los que viste cachas de titanio mecanizadas con estrías para ofrecer
un buen grip, como sistema de bloqueo utiliza un lift-lock el cual se acciona moviendo hacia
arriba la virola de titanio, que viene provista de un inserto de goma para un mejor apoyo,
desbloqueando así la hoja para que se pueda cerrar.
La Twin Lift es una navaja con un diseño de formas redondas, muy ergonómico y cómodo
de usar. A resaltar las terminaciones de alta calidad propias de la casa Zwilling y detalles
como el escudo con el símbolo de la empresa insertado en la hoja bajo-relieve y que permite
abrir la navaja a una sola mano.
En definitiva se trata de una llamativa navaja muy adecuada por su rareza como pieza de
colección y a la que creo que lo único que le falta es un clip de transporte.
- ZWILLING TWIN LIFT 55665-000: Acero: 440C; Mango: titanio; Largo hoja: 72mm;
Largo total: 178mm; Peso: 119gr.
ARMAS BLANCAS a las 11:21
Compartir
No hay comentarios:
Publicar un comentario
Estan invitados a comentar sobre este post...
Inicio
Ver versión web
Con la tecnología de Blogger.
Thanks for the replies, unfortunately this supposed bolster where the rubber grip is either doesn't function correctly or I haven't figured out how to make it work. We knew that piece was the only "moving part" on the handle and was likely the mechanism of action, but despite that....there is no earthly way to pivot, rotate, slide, lift or otherwise use it to unlock the blade. It seems as if the leaf spring inside that locks it in place may even be "too strong". Idk...might have to find a blade smith nearby because I have this thing fully disassembled and had to re-assemble in the closed position because I cannot find any images, instructions, or video of how it is intended to operate.
