D-shaped, square, or rectangular eyes?
Something along of the Manarinhacke in spirit?
The material under the blade on the two is interesting - maybe telling of where they came from? Modified or original? They are pretty wide where a "Rheinelander" isn't.
Are the two wider-bladed ones thinner overall than the large one center-left?
Where did you find them?
Thats a Manarinhacke. It's a pattern local to the area of Venice. As for its worth: It's worth as much as your willing to pay for it I guess? It's rare as in that you don't find them often? But it's without any monetary value.
https://www.google.nl/maps/place/Friuli-Venezia+Giulia,+Italië/@45.9119192,12.7721556,9.25z/data=!4m5!3m4!1s0x477a33a45ebebaeb:0x107098715907c80!8m2!3d46.2259177!4d13.1033646
These are the ones she is bringing home....just noticed the strap on back of hatchet?View attachment 890689 These are the ones she is bringing home....just noticed the strap on back of hatchet?
Skip the jelly and go straight to the wire wheel.Those axes will look a lot better after a quick bath in naval jelly or wd-40, then a scrub with steel wool or wire wheel!
Thanks Kevin...seems I have found an expert!!....the little one has a stamp on it and maybe when she gets it home you can assist with the identification?Those are just your run of the mill axes. Rheinlander pattern. Really common in al of Europe. I would get these at no more then 5 euro's here locally.... The strap is used to secure the head without wedging. Does account for upward movement, but does absolutely nothing for downward movement.
