- Jan 22, 2010
I finally got my belts for the belt sander, I got them from Lee Valley, I got the 180, 320, 500 and 1200 grit aluminum oxide belts, 1 by 30, and I got the leather strop belt and a bar of the green honing compound, I have a Chicago Machinery sander,,almost identical to the Harbor Freight sander,,I was kinda worried about the sander as it was given to me and had thought I might buy a little better quality sander,,but I was surprised the littls machine works great, I took the platen off and the angle thingy on the front of the sander,,it kept getting in my way, the belts came in micronsmmthat innediately lost me, lol,,I had to call Lee Valley to make sure I used them in the correct order,,now this is the first time I ordered belts,,the prder came in right on time, no delays, order correct, etc,,I was little disapointed that the customer service rep was not able to tell me anything about the order the belts were to be used in,,but he was able to help me figure out which belt was the rougher,,the 180 was easy but after that I found it hard to tell,,now nmy question is,I took most of my wife,s kitchen knives and a large hunting knife to the shop to begin my new adventure,the first one was a large thick stainless kitchen knife, I started with the 180 grit and made a few passesuntil I got a burr on the oppiste adge then made a few passes on the other side, the blade felt better alreay, then I took the knife through the rest of the belts and the leather strop as well,,It is much sharper than than it has ever been,,but I was dissapointed in the edge,,I thought it should have been much sharper,,I have read all I can find about using the belts,,I thought I was doing things right but it is clear I am doing something wrong,,do you sharpen till you get a burr with each belt as you go down in grit?,,or just on the first belt?,,I am trying to keep a constant edge on the blades and do not think that is the problem,,help an old guy out if you will thanks
Rick
Rick
