in answer to your request, Watchful;
http://www.bassengineering.com/E_Effect.htm
- a page by a consulting engineer. you can google more evidence youself.
additionally you might look up some of the fights that went on when Edison was trying to get the country to adopt a DC system and Tesla was proposing an AC system.
The ignorant can make anything dangerous(you gave a good example) (any one shorting batteries on purpose should probably be kept away from pointy and blunt objects).
At high voltages (and currents) both AC and DC can be dangerous to those not equipped with the knowlege to use them safely. Even those that do know some times are injured and killed (investigate Arcflash).
"except that there are no 50Hz DC systems anywhere in existence... because all oscillating electrical systems are indeed AC. There *is* no Hz rating for DC systems because it's a continuous supply and return. A 40Hz (I assume you meant 40, rather than 400), a 50Hz, and a 60Hz distribution system are equally dangerous since the human body responds to voltage amount and amperage intensity, not frequency of power."
Please take the time to learn some basic electricity/electronics.
I meant 50 Hz AC, however a square wave is an pulsed DC wave form (you can make a crude one by switching a battery on and off 50 times a second)and so you can have a 50 Hz DC current.
I said 400Hz and I meant 400Hz; FYI, this is the AC frequency that much of our military runs on and has for a very long time.
Amperage is the most dangerous part of electricity DC or AC; however, the frequency can induce irregular heart beat (fibulation) that can kill you at a lower current than you can stand with DC (apprrox 1/10) .
I do grant, however, that there is probably not much (although I'll bet that is measurable) differance in the death rate from 50 hz versus 60 hz shocks.
Enjoy!
