With pin holes and lightening cuts? And matching holes in your scales without clamping them together? While you simultaneously grind bevels on 2 other knives?
That's the appeal of a machine like this. Walk away time. Sure, you can probably do it faster the way you do it now. This can do it accurately, repeatedly, without manual intervention freeing you up to multi task.
I'm guessing the thickness limitations are what they will guarantee a straight kerf for. If it can cut .187" steel it can likely cut .250" steel, but outside of the current kerf straightness tolerance.
Think of how easy it would make fitting guards, or other square hole applications. This machine (if capable as stated) is almost as groundbreaking as a tabletop 3d metal printer, at this price point.
