Cobalt
Platinum Member
- Dec 23, 1998
The secret to SR101 and SR77 is no longer a secret like INFI hasn't been for some time. Here is the info compared to it's relatives. You decide.
So here is what I found using Niton XL2. Not mine obviously. Very expensive device.
SR101
LEC = 1.22 Elements with atomic number lower than 17 (1% C, 0.22% Si is likely here)
Chrome = 1.46
Manganese = 0.69
Copper = 0.27
Fe = 96.36
52100
Carbon = 0.98 - 1.1
Chrome = 1.3 - 1.6
Manganese = 0.25- 0.45
Silicone = 0.15 - 0.35
Fe = remainder
So SR101 is very close to 52100. If you take Lec and subtract 1% Carbon from it, then the remaining 0.22% is likely silicone. SR101 has copper in it. It also has considerably more Manganese. Certainly this is close to 52100 with only minor differences. 0.34% more Manganese than 52100. It has 0.27% copper which 52100 does not. That is 0.61% more elements than 52100.
SR77
Chrome = 3.0
Manganese = 0.74
Molybdenum = 1.39
Vanadium = 0.24
Fe = 93.15
LEC = 1.48 Elements with atomic number lower than 17 (.5% C and up to 1% Si is likely here)
S7 Steel
Carbon = 0.45 - 0.55
Chrome = 3.0 - 3.5
Manganese = 0.2 - 0.8
Molybdenum = 1.3 - 1.8
Vanadium = 0.2 - 0.3
Si = 0.3 - 1.0
Fe = remainder
As with SR101 above if you remove 0.5% Carbon from LEC, then the remainder is silicone. So SR77 and S7 appear to be the same steel.
LEC are elements that do not show up on the analysis due to their low atomic number. Usually 17 or less.
SR101
Chrome = 1.46
Manganese = 0.69
Copper = 0.27
Fe = 96.36
52100
Carbon = 0.98 - 1.1
Chrome = 1.3 - 1.6
Fe = remainder
SR77
Chrome = 3.0
Manganese = 0.74
Molybdenum = 1.39
Vanadium = 0.24
Fe = 93.15
S7 Steel
Chrome = 3.0 - 3.5
Si = 0.3 - 1.0
Fe = remainder
