Here's a BIG stupid question.
This question is about motors. There are DC motors and AC motors. How can a motor be DC but run off of an AC current? And why would you want a DC motor over an AC motor?
Thanks for putting up with this one.
- Loren
Simply put a D.C. motor runs off of A.c. current by use of a converter. The converter can be of a type that will vary the speed of the motor . This can be very usefull on a belt grinder. Sure wish I had a variable speed!
DC gives you more control; especially at the slower speeds. It is also more stable and won't bog down as much when pressure is applied to the belt.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
George Orwell
All of what has been said is very true. Just adding a few things. DC motors come in a lot of different voltages. As has been said before you just cant slap some leads on a DC motor and plug it in. You might have a DC motor that runs on 4-5 volts lets say which is a typcial voltage in a digital board. That means that you have to take the 120 v AC from the wall and first convert it to a DC supply (rectify it as someone has said... this can be done by several different ways....wont go through that here) then bring the voltage all the way down to the needed 4-5 volts (usually by a transformer). Also remember that an AC voltage is a sine wave. This means that it goes up and down from some positive voltage to some negative voltage. It follows this path at a frequency..... if its from the wall this is 60 Hz (60 cycles per second... that is the voltage goes from the some positive value, passes zero, then goes to the some negative value 60 times a second).
Hope this helps a bit.
Michael
Hmmm..... well..... it does make things a bit easier..... a lot less people are getting electricuted with the DC stuff
I dont realy think much of it cause I have been working with it for a while. To be truthful it probably sounds more difficult then it is.
Michael
An a-c motor is a fractional horsepower motor while a d-c motor is a true variable speed motor with an infinite number of speeds up to the max rpm.
