- Aug 23, 2000
Ok.... so.... I took the plung and did some forging today(finally got some time to myself).... not sure if it was a positive experience or negative... but it was an experience....
Heres what I was working with....
1. Found a park with some privacy and worked there away from the crowd.
2. Had the "One Brick Forge" fired up and I believe ready to go fueled with propane
3. The selection of steel I had was L6 (3/16 x 1) and 52100 (3/4 round stock)
4. Tools I had was 24 oz ball pen hammer, wire brush (to get things clean) and vise grip pliers (actually never got to use them)
5. Anvil was rail road track
Heres what happened...
I started with the L6 since it was already flat (thought it would be easir to start with that). Put the stock in the forge and it took some time to get to a yellow/orange color. Enough time actually that I am starting to think that the opening that I made for the one brick forge was too big (I made the opening as big as I could without the brick cracking... apr. 1 1/2 wide by 2... 2 1/2 long). I thought I would want some room. As I worked I noticed that the only steel getting to forging temperatures was the steel in the direct path of the propane. And that was it..... nothing else was getting hot enough to forge.
At any rate, I took the stock and brushed it off before starting to forge. The RRT anvil bounced around quit a bit actually. With what I had, nothing held it in place all that much. It did not prevent forging, but was an annoyance. I noticed that the steel was not moving all that much either. I must have pounded on that steel for about an hour and it was no more looking like the beggining form than when I started (ok... maybe "no more" is a bit strong... I was moving steel but VERY slowly). I also noticed that I lost forging temperatures very rapidly. I am assuming that thats because it was cold outside today (about 50 F). Could I have not been forging high enough.....? I did try the 52100 stock with similar results.
My thoughts.....
Thoughts that was going through my mind at the time.....lets see.... I think the forging chamber is too big.... what do you think.....? I was going to try it again with another brick with a smaller chamber to see the effects.... The hammer I was using..... I am not sure if it was a hinderance. I know a cross pein is used to move the steel in the direction you want it to go. Do you think that the hammer was heavy enough to move the steel.... 24 oz... (was the heavy one that the Home Depot seemed to have.... I want to get a good cross pein but am saving for it now). Seemed that I would forge the curve for the blade.... then straighten the steel out and the curve would either disapper or ... more actually... the steel got real thick. Something has to be done with the anvil....... thinking about getting a portable workbench from Lowes.... clamp it on the workbench... thoughts?
Well... like I said... not a complete negative experience.... but I do need some advice on what to change for my next time... thoughts???
Michael
My thoughts.....
Michael
