Took my recently hung masting axe out to try hewing with it. I felled this bigtooth poplar yesterday. The little stretch already hewn in this picture I did with my felling axe yesterday.
I didn't bring a chalkline with me, I wanted to try hewing backwards and trying to eyeball things. I do plan on using this timber in a planned toolshed, but I don't really care too much if there is some major ugly axe work.
There is definitely a big learning curve to using this axe properly. I'm going to use it some more and see if I get better. Right now the axe is biting in way too much and leaving a very hacked up surface. This is most likely due to my technique, and I was definitely forcing the cuts too much in the beginning. By the end I had loosened up a bit and was possibly getting an idea of the right rhythm, but you can see the cowboy-rough finish I ended up leaving.
I'm a little frustrated that I couldn't figure out how to clean this up without just digging in further. It is most likely my technique, I am not the God of Hewing. But I am also wondering if the bevel angle needs to be dropped a bit as well. I pretty much left the angle the same as it was when I got the axe.
In any case, it was nice to be outside. Closest thing to a mild day we've had in a long while. Sunny, 20 degrees and calm. I am pleased that I was able to get this axe working again. Most likely the first wood it has tasted since long before I was born.
