- Oct 7, 2013
I've seen some photos of custom wood scales with hex holes like the Grivory scales.
How are you guys cutting those recessed holes?
You can buy pins that screw in from both directions so you don't have to do that. They even make brass pin/screws that are long so you can cut off the slot after you screw them together if you don't like that feature. Check out a knife makers supply house and learn about all the cool options you have.
Yes....personally, I find the hex cut unsightly and cheap.
The advantage is being able to remove the bolts with just one hex key. Plus some people just like the look, as it's kind of a Becker "trademark".
Corby bolts are what I use on probably 90% of my work. If you want to make them removable, just cut the slot deeper so there's still something for a screwdriver to grab onto once they're ground flush with the scales.
Chain-ring bolts are another option.
...Sex Screws are another method....
Ok, I have to ask:
What are these?
Would I find these in a particularly disreputable place?
Isn't Sex and Screw the same thing?
If so, why aren't they just called Screw Screws?
Do they come in Stainless Steel or some weird Silicone base?
I'm really afraid to Google "Sex Screw"
"Sex bolts" covers a wide range of fasteners. Technically all these are sex bolts. What they all have in common is that a male part threads into a female one, pulling the scales tight against the tang. Since they're threaded together, they provide a mechanical fastener that won't fail even if the epoxy holding the scales on degrades over time.
Various Loveless bolts (1-4 from L to R) and Corby bolts (5-7) :
The advantage of Corby bolts is that once they're ground flush with the handle, they look like a solid pin. Loveless bolts will always show an uneven ring where the bolt is threaded into the bushing.
Chain ring bolts :
