Hey, Pendentive-- Convex Sharpening Question
Dan--I just saw the video you posted in this thread over in the shop talk forum. Your sharpening technique is a bit different than mine, and I was wondering if you could elaborate on it a bit. It looks like you are sanding along the edge instead of from spine to edge as in stropping. Do you just follow the natural curve of the convex edge as if you were sharpening with a stone, or are you just hitting the edge? Do you form a burr and then switch sides? I usually use a mouse pad with sandpaper on top and just strop the knife, but I am always interested in trying new things.
--Josh
I was wondering the same thing. I would like to thank you for all of the effort that you put into your videos and write ups. I think that it is great that you do so much to share knowledge.
Feth-- I agree-- Pen really gives it his all when it comes to sharing knowledge and skills on this forum, not to mention avatars, sharpening and handle finishing on those villagers, etc.
--Josh
I am probably oversimplifying when I say "I just sand along the grain", but that's really just it. :D
However, there really is more to it than just that. There are 2 things happening at the same time, polishing and sharpening.
Steel does have a grain, and the scratches are less significant if you sharpen/polish along the grain, and not across it.
Plus it's a heckuvalot easier to sand and polish that way. The mousepad method is a great idea for smaller knives, but for khukuris, the tail needs to wag the dog. ;)
In answer to your other question, I am sanding everything: the edge, the face, the shoulder and even the spine sometimes. When I get to the edge, I ease up on the pressure a little and let my fingers extend over the edge a bit. You probably can't tell in the video, but I'm really bearing down on the steel quite hard when I'm sanding. It is at such a high grit, there's really no need to worry about leaving deep scratches.
Yes. However, I don't check it every few strokes like you might have to with a stone. I just sand until the sound of the sanding changes. That is, you get to a point where it just starts sounding smooth - no longer makes that scccrrrratching sound. Then I flip it over and do the same to the other side.
It really takes a lot less attention than it seems. That's why I do it while watching a movie (comedies are best :) ). I've done all 5 villagers in the same fashion so that they all can get similar results.
Now, that said, don't expect a magic finish on khukuri when you're done with it. For that, you really need to use a buffer loaded with compound.
This is more of a "working finish" which means that if you screw up the edge out in the field, or tarnish the blade, you can clean it up and sharpen it quickly and without much effort.
Dan
Cool, I'll have to give it a try. My khuks are already pretty scratched up from sandpaper, and all except my BAS have a patina finish, so I'm not really worried about the scratching.
--Josh
Wow, I hadn't seen those before, thanks for bringing that to my attention Josh! And of course, thanks to Dan for posting such great tips.
