HF 10% off coupon
Right on! Thanks! This just netted me a 4x6 bandsaw for $160 OTD on my lunch break :)
-d
Remember -
- quality bimetal blades are a must (MSCdirect, McMaster, Enco). If you're cutting outlines on thinner stock, get 18tpi
- adjust the pulleys so that they're planar (there's a socket set screw)
- tension it to the highest tension possible with rag on the knob
- and my personal touch: use some tin to create a cover above vent
holes on top of the motor - to screen the debris so it doesnt end up
in the motot's windings
Smart choice !
big thanks here
goin to pick up a mini mill today the said they have 3 instock its an hour drive but i think i its worth it
butch
Butch -
you won't be sorry.
Had mine for a few years, never regretted the decision I made.
Accuracy and power, versatility are simply remarkable for such
small package.
If you want to move it youself, it is bordeline weight-wise.
I can easily move it around on my work bench, but to lift
it on/off, detach the column/head assembly - there's big a$$
nut in the back, on the bottom. Be careful to support the column
as you loosen it.
For a while I was drooling over Square-column knock off of RF-45.
At $1200 it is very good deal and a monster of a mill ... no space for it in my garage.
