Really wishing I had a 2x72 right now!!!
Having made a couple of knives now and trying to improve my grinding technique with each one, I'm realizing a huge part of my battle is my little Harbor Freight 1x30. It seems to do fine as far as motor strength at the rate I'm pushing it but when it comes to lining up my plunge lines from side to side as well as getting them to match side to side, I'm realizing that due to the fact that each belt I put on tracks a little different, one exposing the right side of the "platen" and another exposing more of the left makes for inconsistent grinds. Adjusting the tension/tracking knob only does so much. If I can't get the belt to line up dead on with the platen, I end up with inconsistent grinds and the more time I spend trying to fix one side to match the other results in too much change and I have to go back to the other side to again try and fix/match it! Incredibly irritating!
I just recently received my first order of belts from Supergrit and got a few Ceramics of different grits, Trizact and some other higher grits and already snapped one Trizact due to the fact that it was jumping all over the place because I couldn't create enough tension to keep it steady and at the same time in the right position against the platen. I've tried a few of the other belts now and all of them fit differently and I'm super irritated that there's no way to separately adjust the tension as well as tracking! I feel like my investment in some good belts is now a waste of money possibly. I want to do exceptional work but doing it with this little POS is severely going to hinder that I've realized and has just added a lot of frustration to the learning process.
BTW, in respect to the belts and I can't believe the difference between a standard OA belt and these low grit Trizacts and Ceramics for stock removal! HUGE difference!!!
Any tips on dealing with the tracking and or tension? I really want to take advantage of these new belts but haven't figured out a solution.
Rant over!
Rant over!
