What do you mean stuck? It seems to move freely as it should. My problem is I have to twist it until isn't centered for it to be tight, which is what's causing the belt to shift to the side. When I center it, the belt is too loose.
This is good info! Thanks for this. RussThe whole tension adjustment module can be moved back and forth by loosening the bolt and lock nut at the bottom of it. I needed to tweak this on both of mine to get things tracking smoothly and close to center.
edit: A little more detail. Not all 1x30 belts are created equal. Some are a bit longer than others, so when you have the machine set up to run brand X, those from brand Y may be too loose and won't track properly, or vice-versa. This is what this adjustment is for, to take up slack or give a bit more to suit diff. diameter belts. The tension/tracking knob itself is for fine adjustment once the whole module is set correctly. :thumbup:
Glad to help. :thumbup: My first one didn't have a manual, and I used it for a long time just tweaking the fine adjustment wheel with less than satisfactory results. One day I started really looking the machine over and discovered that I could adjust the whole module by loosening the lock nut and rotating it forward or backward. Once you see it, it seems really obvious, but I overlooked it for a long time.![]()
