HI Bilton arrived!
I came home today and to my delight found a small box with Himalayan imports on it - why it could only be my Bilton. I know we all say this, but I totally didn't expect it this early! WOW! fast shipping!
I opened the box to greedily stare at my new toy.
Red Leather sheath!!! thats kind of differant!
Unsheathing the knife and giving it a quick cleaning showed a cute little knife.
The kami marks [does anyone know the maker, which factory and what city/town this was made in? I'd be curious to have all that info to write down and keep with the blade.]
Now from there things got interesting.
Giving the knife the "whack test" immediately showed a couple of things. Giving it four good whacks on a 2X4 immediately showed thee small chips or indentations in the blade. I assumed this is becasue the heat treat may have left a little bit of soft metal on the edge. I gave it the old "sandpaper on the mousepad" trick, first some 400 grit, then some 600 grit, and they buffed right out. While sharpening, I noticed that there is a large section of the blade that has no edge at all - like a butter knife or a chakmak.
This area here is literally flat, almost like a chakmak would be - you can visibly see the flat spot when held in the light.
Since this is such a small and light blade, I'm assuming that they anticipate the user plying the "sweet spot" for everything, and since it's so small, there really would be no heavy use intended for it anyways, so any cutting or slicing you woud do would be done from the sweet spot forward. perhaps other bilton owners can comment?
The mouspad trick did in fact buff the dings out of the blade, and giving it another "whack" test did not put them back, so I can only assume I was correct in the soft edge left from heat treat. The sharpening also brought out the tip a lot more as well.
All in all, it is a fun little mini-khuk that will make a nice conversation piece, and perhaps even a kitchen use or small box type knife.
looks like The Prince's work (Rajkumar) I have a bilton by him as well in my kitchen drawer its getting a nice patina on it as well. I use it for food prep. it works wonders
The kami is Rajkumar, the factory is shop 1 (there are 2 shops) and the place surya benai,nepal.
can I ask a practically dumb question as this point? Why is he called the prince? is he actually a prince of some sort, and if so, of what/whom?
I believe he is called the prince because that is what his name translates to.
I actually don't consider this a dumb question, I was wondering this myself, being I own a bilton by him & have a tarwar he crafted on the way,
Thanks for the Answer Karda
I had purchased a Bilton to give to my little brother this past Christmas. I had previously bought him an 18" AK and thought this would make a nice conversation piece for his office desk. I figuered the toughest workout it would ever get would be opening his daily mail. However, I was soon thinking otherwise when I found myself on a week long canoe trip with no other blade but the Bilton I had purchased him. :eek:
The trip took place on the Peace River in western Florida a few months back. My brother and I were wanting isolation and we definitely found it on this particular stretch of the river. Not a a single soul (not another boat, canoe, raft, fisherman...nothing) was seen until the very last day of the trip. When we stopped for the first night, we soon discovered (gasp!) we had forgotten the designated chopping khuk (his 18" AK) in the truck. As we were already 8 hours downstream, all the big khuk's work was now going to fall on the Bilton's shoulders.
Although not designed to be a true chopper, this blade was put to the test with some extensive time spent batoning firewood each night. It was small but it managed to split the 5" chunks of seasoned oak we had brought along with very little problem. We would just position the blade on the corners of each chunk and go from there. It was also used to cut down various dead palmetto branches found along the banks which were later used for fire/shelter. Heck, we even took turns sleeping with it to put any potential fears of the "boogieman showing up" at bay. :D
I owe alot to the Bilton. It's a tough little khuk built equally as well as its bigger siblings. I give it a :thumbup:.
Regards, Mac
Great post and pix, thank you for sharing
Giving the knife the "whack test" immediately showed a couple of things. Giving it four good whacks on a 2X4 immediately showed thee small chips or indentations in the blade. I assumed this is becasue the heat treat may have left a little bit of soft metal on the edge. . . .
Often with the polished blades there will be a layer of soft metal a few thousandths of an inch deep that is soft. Since this doesn't happen with villagers and True villagers, the going consensus is they hit it real hard on the buffing wheel and anneal a small bit of the metal to be softer through heating it on the wheel.
When I get a polished blade that I'm going to use, usually the first thing I do is remove that layer of softer metal on the edge bevel.
That was sort of my thought as well, and after a thorough sharpening it alleviated both the flat spot and the soft parts, and then it passed the "whack" test easily. Now it sharp thoroughly and is retaining its edge perfectly!
It really is a fun little knife!
Just wanted to share with you a pic of my bilton by the same Kami but has a horn handle its getting a natural patina. I chop up chicken, potatoes, oranges etc with it. It also came with the same color sheath which is now stained a little with cooking oil
