HI/Hmong friendship knife
Howard Wallace
Moderator
I’ve been playing around with one of these knives.
The first thing that strikes me is the beauty of the wooden scabbard. I really like to see the wood grain exposed. The rope attachment is quite handy and serves as an instruction for anyone who would like to use this versatile method for carrying a khukuri or other knife.
http://sphotos.ak.fbcdn.net/hphotos...19007969667_1068564063_31442440_3696213_n.jpgThe handle is also quite beautiful. The design is appropriate for a gentleman’s knife that will be carried and perhaps called upon at times. For a laborer’s knife I would go with a smoother handle without as many possible abrasion points like brass rings or step junctions. That said, I took the knife out and split enough wood for a nice campfire without any problems for my hand.
The big belly of the blade made for easy splitting and chopping, while not dropping the point in the manner of a khukuri.
The brass rings on both the sheath and the knife handle did loosen up and slide easily. Between the two carry photos above one of the brass rings slid off the sheath, and it was only later that I discovered it missing and hunted the ring down in the grass. Some thought should be given as to ways to stabilize these rings. They add a lot to the sheaths for both decoration and functionality, and snazz up the handle for decorative knives, so I don’t think HI should give up on them. Perhaps they could be stabilized by a small tab that extends into the sheath or handle, or perhaps a dab of laha would do it. I'm sure the kamis and sarkis of HI are up to the challenge of figuring out how to stabilize the rings.
Namaste,
Beautiful set, scabbard and blade.
Looks like a Pharaous knife:D
Doesn't the set tend to slip through the paracord loop?
The carrying rope is some type of inexpensive synthetic, not paracord. I may replace it with a natural fiber. The sheath is quite securely held, which is why I took the closeup. I think many of the forumites may want to try this out. 4 circles around the sheath, tie with a square knot, then use the long ends to tie around your waist, sling over the shoulder, tie to the pack, tie on your jeep, hang on a nail in the barn, etc..
Very nice. What was the spine thickness.
here's a thread on another site which shows decorative knots for dha knife/sword scabbard baldrics.
Linky
wicking a dab of superglue under the brass rings might help hold them better (or a discrete brass brad or tack)
Thanks Howard Wallace for your review.
This is the first batch of production, then still need some more rounds of improvements.
When I made my copy, I also anticipate this issue. I make sure all rings are tightly fitted to the horn handle, then I supper-glue them to prevent slipping off.
Besides the strengthening of handle, avoid shock or crack, the brass ring is used as decoration as well. If the edge of brass rings are still sharp, you can use a fine file or sand paper to round them up. For sure it would offer an enjoyable grip.
My HI piece is now in the air, would reach me in few days.
All the best.
Hung
I didn't know what to call it...:o
Will have to try this one...it may turn out to be the super-el-cheapo-lightest-baldric-carry out there:D
Already have some "improvement ideas"...:rolleyes:
