- Mar 17, 2006
Hi Guy's
Who sells the 1150 aprox deg silver solder?
Thank's
Thank's
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
How do you use it on a knife? It is too low a melting point to use before heat treat, and too high a heat required to use after.
Teach me somthing.
Mike
Maker
The Loveless Connection Knives
You can make your own by alloying fine silver with brass. All you need is a scale, MAPP gas torch (or other suitable torch) and a crucible.
Hard- 5 parts silver to 1 part brass
Medium- 3 parts silver to 1 part brass
Easy- 2 parts silver to 1 part brass
Sometimes you can silver solder parts to a blade or heat treated part after the HT, simply by shielding the edge portion of the blade (or working portion of the part) with an insulating material, like KAO wool or KAO wool saturated with clay or some type of binder. Also, in some cases, you may be able to insulate the soldered part prior to HT in the same way.
If you think in terms of isolated “facts” and scientific “absolutes“, you’ll probably never try any of this… Yet, there’s usually ways to beat the odds with most things... but, it often requires a greater understanding of the materials, skill, experience, science and logic than the “scientific logical approach”.![]()
