Usually, they are there, you just can't see them. They are incorporated into the design, and with good metal burnishing skills and matching alloys, the pin becomes invisible. Other pins and screws may be buried under inlay work.
In most cases, the bulk of the pins are in the liner, but not through the scales. The scales are attached with one or two pins.
Another method is to have the butt end of the scale fit over the liner with a little recess to grip the liner. The front gets one pin to hold it down.
I use a variety of rotary burnishers that will blend the joint to invisible. A very good fit is a must as well as perfect round holes and pins. Annealed metal helps a lot, too.
