- Oct 18, 2001
Are hidden pins as strong as full width pins?
(See diagram below for visual explanation)
I'm sure there is some difference, but I wonder how long the pin really needs to be in order to provide 80-90% the strength of a full-width pin.
I'm sure it also depends on the handle material, pin material, glue used, tang style, etc.
For the sake of argument, let's assume the following:
How much strength is really being lost by the pins not extending fully to the outside of the handle material?
Dan
1 = Full Tang, Full Pin
2 = Full Tang, Hidden Pin
3 = Hidden Tang, Full Pin
4 = Hidden Tang, Hidden Pin
- the handle material is stabilized/strong
- 2 hidden pins - 1/8" diameter
- the blank is a typical hunter-sized blade - 1/8" thick, either full or hidden tang. (for the hidden tang, there would still be 2 slabs, just cut to match)
- Glue-up is either JB Weld, 2ton Epoxy or Acraglas.
Dan
