Well I just started last night on my first knife. I have a new respect for all the full time knife makers. I can't wait to finish my first one so I can start my second one. I bought some cobalt drill bits and they work great.
My first problem that I need some help with is...
What method should I use to cut out the steel? Other than buy a bandsaw (I plan on getting on in the future) I have only start for a little while. I have drilled some holes out and started using a hack saw, It seems to cut okay but it keeps binding up, the part were the hole is drill and the blade cuts through it catches the blade and makes it hard to cut. Do I need to buy a better blade to cut the steel? I am going to try and get a dremel It seems like I have heard this is goo for cutting through steel, is this true? Does any one have any suggestions on what I should do to cut out the steel. here are the tools I have to work with.
Bench grinder with stone wheel and flat disc
Drill with cobalt bits
Flat and round file, flat file is double cut
A cordless 5 1/2" circular saw
Hack saw with new fine tooth saw
Possibly a dremel if it has a goot cutting attachment
A lot of determination
If anyone can help with ideas or suggestions please let me know, I need help.
