Ron :
Originally, you compared a high alloy stainless steel to a simple carbon steel.
Since you disagreed with what I was calling a simple carbon steel I simply clarifed what I meant by the term and that yes it included low alloy carbon steels as well as the pure carbon ones, so it referred to both steels like O1, 52100 as well as pure carbon steels like 1095. There was no retraction, the two statements say the same thing, the latter one just includes the defination of simple steel that I had in mind when I wrote the former.
It is a common misconception that low allow carbon steels like O1 have a greater wear resistance than common cutlery stainless steels or are stronger and this is simply false (the strength issue is really off due to the difference in the heat treats used) - when the stainless steels are high carbon very high alloy, as are commonly used in cutlery.
To clarify, there is an exception to this, since the non-stainless steels are inherently tougher they can be hardened to a much higher RC and still remain functional. It may indeed be the case that simple steels like W1 at 64-66 RC would outlast stainless ones at 59-60 RC, but I can't think of anyone who offers such blades in the cutlery industry outside of Japanese laminated chisels, which I have little experience with.
If you move beyond simple steels, you can easily get muchgreater strength and wear resistance out of non-stainless steels. For example, M2 has 9 times the alloy percentage as O1, and will give much greater edge holding ability than the above stainless steels as well as will allow a greater cutting ability by raising the functionality of low cross section edges.
Yes, some Mastersmiths may use 52100 or 1095, but just the fact that they use it does not make them the best of ?carbon steels?
That was not the point, you made the statement that no "quality" knives were made of simple steels, your presupposition is incorrect by both the defination I had in mind when I used the term, and even the one you stated - unless you want to claim that Mastersmith level blades are not quality knives.
As for steel being an alloy, no you are not going to see that in something like a Handbook, you will want to look at something more fundamental, try a materials text.
-Cliff
