Thank you, I used one of the outer ropes and brought to bright orange then used my press to forge it flat after heating first and twisting tighter.Welcome kurtmm.
Can you elaborate a bit on the question? What was your issue with the wire rope?
I have had great success with another vendor but have lost the receipt so forget who it was. Who is HTT&R? I can try them, Thanks.Have you had success with wire rope from other sources? What was the quenchant and temperature?
I have used HTT&R for many years and never had any issues. I haven't bought any wire rope from them, but they usually carry only the best products.
Yes, I have bought ceramic fiber and fire bricks from them also, And I do weld and twist tighter prior to forging and have had great success with other cable but,Sounds like it might be 7X19 cable which is pretty flexible. I would think the cable for welding would be 1X19 which would have larger strands. I'm sure you welded the ends together prior to heating 'n twisting? I've never used their cable, nor any cable for welding, but the other products I've ordered from them have always been good stuff. They've got a good rep for quality stuff from what I've read.
Ok, HTTR, Now I see it! Anyway, The strips were within the cables. Bearing the Mfg. name, blue colored and about 3/8 wide thin plastic.You said it had plastic strips in the cable do you mean the center core strand was plastic instead of steel? I had bought some cable from High temp tools, which is who Stacy is also talking about, HTT&R, and it had a plastic core and I was actually contacted by High Temp saying they had a batch come in that was supposed to be steel core but wasn’t and they refunded the cable I had bought. You may try calling the supplier and asking them your question
