Within the same steel, higher RC always means more wear resistance
Originally posted by Paracelsus:
<center> SNIP </center>
When your throw in non-iron based blade materials like talonite, all bets are off. Talonite normally has an RC in the low 40's, but holds an edge better than many much harder blade materials.
Stellite is not really as soft as some make it out to be
there are hard cobalt/tungsten/chromium molecules in a softer matrix and that is what is measured by the rockwell tester
...there are hard cobalt/tungsten/chromium molecules in a softer matrix and that is what is measured by the rockwell tester.
One point I'd like to note, however. I think it might be worth considering that heterogenous structures like dendritic, damascus and wootz steels behave much differently than homogenous materials like normal steel and talonite. While the matrix in those structures may be relatively soft, they gain a great deal of strength and wear resistance from the much harder inclusions or layers in the composite. The soft matrix can erode a lot before the harder material is influenced.
Isolated parameters like the Rockwell hardness of a part of that structure may poorly define its overall performance when compared to homogenous materials we are more familiar with.
Thanks for pointing that out Jerry, I have noticed that transition point with steels and just was not making the connection here. It was probably because of the significant difference in matrix composition which could quite easily make the transition points happen at two very different times.
There are basically two stages of blunting, the matrix deformation and the carbide wear. The second is much longer than the first, but with a hard steel the first one is still very long and what most people refer to as blunting in general. Since the cobalt alloys have a soft matrix the very edge may deform and go out of crisp alignment very quickly. Thus the optimal performance takes a sharp hit quickly. However after that the wear resistance becomes the dominant factor and they compare well to the best steels in that area.
In regards to the Talonite monster... It is still going strong! I still
am using it as my number one chopper everyday, and I am still an
enthusiastic Talonite supporter.... Boy does this stuff hold an edge or
what?
The only thing that is taking some getting used to is the technique of
sharpening the blade. I think I'm up to four times on the Edge pro ( not
bad for over a year! ). The first three times I got a scary sharp edge
fairly quickly, but the last time it took me nearly an hour to regain the
sharpness. Is this what is known as the slippery edge? Also I've found that
the Talonite seems to respond to my fine stone rather than a coarser stone.
Thus it seems fairly well shown that Rc per se often, but not always, is an indicator of more wear resistance whether considering the same steel or different alloys.
