Higo No Kami - What is the other steel in it?
So I have your authentic Nagao modern standard Higo No Kami with Brass, XL 120mm (measures larger but that was the advertised size of course) - the warikomi / honwarikomi is supposed to contain Aogami Blue paper steel #2, but I am wondering what kind of steel is in the core (or is the Aogami the core, and the mystery steel the laminate around it???)
I cannot find info of what the specific combination is in most of them.
You can find the one I refer to on Amazon titled "Higo no Kami Aogami-Honwarikomi Tokudai (sizeXL), Nagaokoma, Import from JAPAN " - I bought it elsewhere but same knife exactly.
I have a few others but this is where I think is best to start.
Commonly, white steel. Its like mid between blue and stainless. Theres super blue too.
Japanese Blue and White Steel
The most widely available Japanese tool steel is manufactured in two forms: blue steel and white steel – named for the color of the wrapping paper used by the maker. Knowledge of these two form’s chemical content and tempering process allow the woodworker considering Japanese edge tools to make some tradeoff between hardness and toughness in the blade’s edge qualities. Hardness means the temper and content of the metal is such that the blade can be sharpened to a very fine degree but results in a somewhat brittle edge prone to chipping or crumbling. Toughness refers to the ability of the edge to avoid damage, and thus stay sharp longer.
Blue steel, or Aogami, has tungsten and chromium alloys added to the edge steel that make the hardening temperature less important, resulting in an edge that tends to be tougher, and thus stay sharp longer than white steel, while not taking on as fine an edge. White steel, or Shirogami, contains fewer impurities and does not have the alloys added, so the hardening temperature range is very narrow. The blacksmith forging white steel has to be very skilled, but the result is tool steel that can be sharpened to a very fine, but more brittle, edge. Both forms are further broken down into grades based on the carbon content of the steel.
The better Japanese blades are laminated by hammer welding the edge steel onto an iron or softer carbon steel core, the actual process proprietary to each blacksmith. So, while there is science in the forging, hammering, heat treating and tempering processes, more than anything else the quality of the steel is the result of the care and skill of the blacksmith. These are family run businesses that trace their lineage back to the edged weapon makers to the samurai and it takes 10-15 years at minimum to perfect the craft. Considering this learning curve, it is no small wonder that Japanese blue and white steel blades made by traditional methods are superior to machine manufactured products.
When trying to decide which blade to buy in a Japanese tool you should bear in mind the difference between blue steel, white steel, or the exemplary special process steels like Damascus, is not one of quality. There is a wide range of qualities available in both types of steel, and in the chisels made with from these steels. You can get acceptable toughness in very hard white steel chisels while taking advantage of that form’s ability to yield a very sharp edge; or you can get a quality blue steel blade that can be honed and sharpened very finely. And of course it is quite easy to get neither hardness nor toughness in a substandard steel blade, blue or white, from an inept or sloppy manufacturer. The chisels that we are offering are all at the higher end of what is available. It really boils down to the quality of the steel and the skill and care of the blacksmith. So, consider the edge qualities you want in a chisel and buy your Japanese edge tools from a trusted source. Either form of steel in a quality tool will yield outstanding results.
The core steel is either blue or white.
The cladding or outer layer is usually a mild steel. Basically wrought iron.
Has a trace amount of carbon 0.03%
Doesn't Harden
Allows the blade core to be very hard with out shattering
I believe the Hitachi mild steel is called "gokunantetsu"
There is a stainless version too
Correctly answered above. Gokunantetsu (極軟鉄) simply means Very Soft Steel.
Nagao uses shirogami(white) aogami(blue) as well as SK5 as core steels. I don't know if they use any others.
