- May 1, 2016
I just got another Higonokami, this one has the tanto tip (Stated as "Sword Blade") instead of the reverse tanto, it is one of the "Large' Sized ones, with a black parkerized brass handle
The blade lays off center when folded shut, and when closing the heel and flat of the blade scratches against it - which when facing the blade from holding position so you see the spine while opened and holding it, the right side is being scraped, or if you are looking directly into the folded handle when closed, it would be the left side.
It is not in any way loose so it is not caused by a loose pivot like my SK steel one was, which I tightened with a hammer and that fixed the problem all together
I need a solution to this and am open to advice of any kind
