Higonokami update.
It's all about the blade.
That statement puts it all in a nutshell about this this knife. The blade is a triple layer blade, from what I understand. Not unlike the Swedish Mora laminated blade. It cuts great, and with a tiny bit of honing it gets very scary sharp. With the slight curve of the cutting edge, it's a slicing demon. I wouldn't want to get in the way of that blade. I now have an understanding of the Japanese blade fans. In the past few days, it's cut everything I put it to with almost zero effort. This blade is like somebody took a bare 327 block to a primo automotive shop and had a totally blueprinted engine built from the ground up. It's all about the performance.
But…
In the past few day of using this knife exclusively, I've discovered a flaw. It's not a fatal flaw, but one that keeps reminding you that this is a light duty pocket knife in spite of having a primo blade. The handle, shaped from a single piece of sheet metal, has very thin edges on the bottom side where the blade nests. This is not a problem in normal light use, but prolonged whittling or heavier cutting like breaking down boxes, makes for some hot spots. The thin edges dig a bit, and the scalloping on the edges are a bit irritating. That makes for a slightly frustrating experience when using this fine blade, not unlike taking that beautifully built 327 Chevy engine and dropping it into a Yugo. Ya got a great engine there, but it's going to waste in that car. This blade is going to waste in that thin sheet steel handle. On the other hand, it's now easy to open with one hand using the thumb lever. OMG, I'm carrying a one hand opener!:eek:
All in all, it's kind of like carrying a nice quality strait razor around in a pocket. Great cutter, but limited by it's overall package. But.. did I mention that it's a great cutter? Kind of like an Opinel, you overlook the quirky limitations and weaknesses of the design because it cuts sooo darn well. Okay, maybe not a Yugo, maybe more like a 327 stuffed into a Vega.
It's all about the blade!
It would be simple enough to just make another handle from wood, brass pins, and Chicago screws.
I got a Higo back a year or so ago, and felt the same way about the handle not being up to the blades potential. I have been meaning to remove the blade, and re-make the knife with a back spacer, brass liners, and wooden covers. I do love the blade, and used to wrap a rag around the shell for any heavy cutting.
One thing I learned with mine was, if one is to quickly snap cut a piece of string from the roll hanging from the ceiling of the shop, that one should not forget that it is a light friction folder, and if you are not holding the blade tab, that the blade will continue moving until it stops, buried deep into your finger!! Only a mistake "one" makes once! ;-)
I find them to be great shop knives, with wonderful edges that I've tested personally! Surely something that should be in any "budget knife" drawer.
The handle issue exists with the Douk Douk and the Mercator K55K. Been thinking about the Mercator, but can't commit due to the handle.
My two Higonokamis are reserved for desk or office cutting tasks. They are great for that and do not scare the weak.
The other problem that comes with a metal handle is, if you get stuff on your hands that is even a little bit slippery, the knife becomes dangerous in hand. Don't even think of using a Mercator to dress a deer. I was dicing up some chicken for a stir fry with the high, and it got a bit slick. Switched out to a Victorinox parer.
The blade was not centered at all on my Higo, there was a lot of room to one side.
So I pinched the handle, so the blade sits snug.
It scratches the sides, but it's also slowed down when you open or close it.
I was on the fence until I saw a tanto version at Knifecenter.
Black handled tanto, incoming!!
Thanks, guys.
rolf
Has anyone tried any of the Ohta models?
I have always admired the fancy ironwood and Damascus Ohtas. However, he has a new line in simple wood and D2 for around $60.
They suuuuure are tempting. If I end up getting one I will post back here.
