Hiking Stick FAQ
Buzzbait
Here’s Buzzbait’s little gift to you guys in the Wilderness & Survival Skills Forum. I’ve been reading and searching through the archives lately, trying to find as much information as possible on hiking sticks. I also searched the Internet quite heavily and had a few ideas of my own. Dying to put all of this useful information to work, I set out to make myself a good, hard use hiking stick that would last me a lifetime. I wanted something that brought out the essence of the Adirondack Mountains. I also wanted the stick to be functional, but without a million gizmos attached to it. So here’s my little hiking stick FAQ. It encompasses pretty much all I know and have learned about hiking sticks through the years, and tells the story of how I made mine.
Wood Selection: There are many types of wood out there from which a hiking stick can be crafted. Many people prefer rattan for its lightness, diamond willow for its beauty, and ironwood for its strength. Seeing as I had an Adirondack kind of theme going for myself, I chose cedar. First off, cedar is quite durable. I’ve fished a man made Adirondack lake for years. It was originally a canyon field with cedar trees, and was subsequently flooded as a log flow during the old Adirondack logging days. This was over a hundred ago, and the cedar trees at the bottom of the lake still stag my fishing lures on a constant basis. I figured that if these trees has been at the bottom of this lake for a century, and still hadn’t rotted away, cedar was plenty resistant to the ravages of time in the mountains.
Cedar has a natural beauty about it that’s hard to match. Cedar is also quite strong, which was proven by my efforts to obtain it. And of all the woods I tried out, cedar was the lightest. Lastly, I was able to find cedar. My area of the Adirondacks is filled with cedar, and has precious little of the more common hiking stick woods. So cedar it was.
Stick Selection: My next trial was to find a quality stick. It took some searching, but I managed to find a large dry area of standing dead. Many of the cedar trees had been marked for removal by the NYSDEC, so I wasn’t impacting upon the wilderness at all. One tree was particularly large, with a couple of smaller trees growing from its base. I grasped the smaller tree I had in mind, and used it for leverage to climb my legs up the larger tree, and then put all my weight on the sapling to pull it down. Once I’d managed to bring my choice to the ground, I measured out the best area to use as a hiking stick, added a little to my measurements, and chopped the ends off with my trusty Buck Big Sky. Yes, a machete would have been easier, but the Big Sky was what I had on hand. It performed admirably for such a small fixed blade.
I guess I should talk a little more about stick selection. I purposefully chose a length of cedar, which had a nice fat top end, and tapered down to an approximately one-inch bottom. The length also had a natural bend in its length, beginning very close to where I’d be placing the handle grip. The bend was very important to me, because I like a small mechanical advantage in the pendulum motion used with a hiking stick.
While it’s almost always important to find a stick with no cracks in its length, this rule does not apply to cedar. Dead cedar saplings almost always have cracks, which never seem to affect the overall strength of the stick. I think of them as character marks.
Initial Preparation: So off I went with my stick, threw it in the back of the pickup, and headed back to camp for some a little wood crafting. Once back at camp, I set to work on debarking the stick. I used the Big Sky once again, which proved to be perfect for this job. I took long smooth strokes, only digging in deeply to remove some pithy areas that had begun to rot. I also had to force the blade through the stick’s many knots, smoothing them as much as possible.
Once the debarking was done, I used my small Buck Cadet slip joint to smooth some of my strokes out a bit. I then proceeded to use 150 grit 3M Sandblaster sanding paper to begin finishing the surface. My final sanding was done with 320 grit Sandblaster until the cedar had a smooth velvety finish.
Final Preparation: As I ran out of time at camp, I was forced to move the project home with me. Once home, I gave the stick a couple of heavy coats of MinWax pecan colored stain. Once that had been allowed a couple of days to dry, I started layering on coats of spar varnish. Spar vanish is what is commonly used on the rails of boats. After applying four coats of spar, with a days drying time between coats, it was time for add a few adornments to my new hiking stick.
Mistakes: Loving the looks of the beautiful finish on my stick, it occurred to me that certain procedures should have been done before I began staining the stick. First off, I needed to cut areas for the handle and foot cap. I also still needed to drill a lanyard hole. Take my advice and do this before you stain the stick. These tasks took me twice as long, paying careful attention not to mar the finish.
Feet: The foot cap on my stick is actually a copper cap from the plumbing section of the hardware store. Many people use steel spikes, brass end pieces or rubber foot caps. I ‘m not much for rubber. Steel spikes don’t work well on the rocky creek beds I frequent, and I couldn’t find brass. The copper foot cap should work out well though. I simply carved and sanded the very end of stick until the cap would almost fit. Then I just pounded the end on.
Lanyard: Many lanyard holes are drilled so that one can see through the hole as they grip the stick properly. I took a different approach and drilled the holes sideways. I then proceeded to braid a lanyard using two lengths of black paracord, and one length of rawhide. I ran the braid through the hole, bundled the ends into three groups of two, and proceeded to finish the braiding with the same three-strand braid method. If you have no idea how to braid, just find a woman. They same technique is used for braiding hair. I learned the braid pattern off the Internet, but my wife provided some invaluable knowledge on the finishing technique. Having one length of slightly longer rawhide left, I rapped the rawhide around the end and made a knot.
The braid is very strong and should have little stretch. The secondary braid is VERY strong, and provides the much needed strength to keep the lanyard from unraveling during use. The length of the lanyard took a little time to work out. Trial and error was the method here. I finally arrived at a length that allowed me to grip the top of the handle area, and still had some room for stretching later. So why did I braid? Braiding is quite strong, very pretty, and spreads out the pressure of the stick throughout its length and width. If any of you have ever used a single piece of rawhide, you know how that can begin to dig into your skin quickly during a hike.
Handle: After cutting a wide groove in the stick, which was the same thickness as my rawhide, I began a simple wrap. I draped a strand of rawhide and a strand a paracord next to each other, and then wrapped them together from top to bottom. The first ends were laid under the wraps and left hanging out the bottom. When the wrapping was finished, I simply made an overhand knot in the end and let the tag end hang.
I decided on a combination of rawhide and paracord at the last minute. Both mediums provide a good grip, but rawhide alone has some problems. Rawhide isn’t very forgiving, so wrapping a curved area would create gaps. The paracord is very strong but malleable, filling in the gaps nicely. And as the diameters are just slightly different, the combination creates a ribbing effect for an even more efficient grip.
With all that said, the best is yet to come. I’ll be taking my Buck Cadet slipjoint to this stick, and carving mementos of my various hiking experiences. I’ll be headed back to the mountains this weekend for a weeklong trip. I plan on adding a few artistic embellishments in this time, as well as a fishing ruler along the bottom. I guess that only time and a little hiking will tell if my theories and construction run true, but I’m quite hopeful.
Excellent post and pics! I too have been on a quest for the perfect hiking stick. Yours came out really nice, mine doesn't look good, but it's functional.
Since I'm in a writing mood, I decided to go into the proper use of a hiking stick. Unfortunately, I hit the maximum character limit for a single post (my first time). So here's a little addendum to the hiking FAQ.
Use: The obvious use for a hiking stick is to balance oneself while hiking through rough terrain, but this one aspect is but a small part of a good stick’s possibilities. Let’s talk a minute about the obvious though. The proper way to use a hiking stick is to place your hand through the bottom of the lanyard, so that the lanyard strongly supports your wrist. This will lessen and properly distribute the weight placed on your stick hand. The proper use of the lanyard will also add strength to your grip, helping give you a firmer foundation on the ground. Hikers who use a stick will also notice that a well-held stick will “lighten your load”. Because the hand and arm are taking some of the weight off your feet, a hiking stick will ease the burden of a heavy pack.
Other than the obvious, there are actually a myriad of other good uses for a hiking stick. I do a lot of trout fishing in rivers and creeks, jumping from stone to stone. A stick allows me to not only gauge water depth, but also acts as a small pole vault to distant rocks. I can’t tell you how invaluable this one aspect is. While I’m on the subject of fishing, I’ve previously made passing mention of its use as a ruler. Not only can a crude ruler be marked on the stick, but a weight table can also be fashioned. Just check your local fish and game department for a length/weight conversion chart. You can either carve weight estimates into the stick, or measure the length and girth of the fish for later reference.
When it comes to primitive camping, a good strong stick sits high up on the list of needed tools. You could search around for a stick to use, but having one on hand during the cold and rain is certainly a benefit. The stick can be used as a tent pole when needed, or part of a primitive cooking rig. A good strong stick also makes a serviceable pry bar when logs and stones need to be moved and rolled about the camp.
A hiking stick can even be used as a crude method of storage. While I don’t personally subscribe to hanging everything but the kitchen sink on my stick, my stick has over 25 feet of paracord and rawhide lace to be used if the need arises. I’ve even seen mounts for cameras screwed into the ends of walking sticks, which can be of great advantage when taking certain shots. Some people like to embed a compass in the top of their stick. Fly fishermen (has anybody noticed my fascination with fishing?) sometimes even keep spare leader line wrapped around their stick. The key is to place useful items on your stick, but without adding excessive weight or placing all of your hens in one basket. Sticks get lost from time to time, and all of your gear shouldn’t float away with them.
A good stick also possesses some ability as a defensive weapon, should things go bad. The staff has been used for centuries as the primary weapon in certain cultures. I have to admit to never using a walking stick as a weapon, but I do feel more comfortable with it. The Adirondack Mountains have few large predators left, but bear, moose, and coy dogs can be found. I’ve also heard tale of angry bucks goring humans during the mating season. A large beaver could also make a formidable enemy. And last, you are not completely isolated in the woods from man.
As I do quite a bit of canoeing, I’ve found it’s handy to keep a stick with me. Canoes and boats get stuck on rocks, where a good stick can be used to shove oneself off of the blockage. A stick is also handy for shoving oneself off of shallow sandy shores.
Can I think of any more uses at the moment? Not at the moment. But you can bet I’ll be adding anything I think up later. :)
The hiking stick also makes a good coat/hat rack when taking a breather too :)
And can be a rifle rest if it is huntin' season...
I like "disposable'" hiking sticks...cut a winner, use it for the weekend and leave it at the trail head for the next person.
Great post!
Ebbtide out.
Thanks, Buzzbait! I learned a lot of good tips and I really like the "fit and finish" of your creation. You never know until you ask...would you entertain the thought of making me one similar to the stick shown and send me an invoice for it? I would appreciate having a hiking stick just like this one. Finding time to make one at this level of skill would be hard for me. If interested, please let me know, and good post...Thanks.
To tell you the truth, I never really thought about selling something like this. I have no idea what to charge, or how to package something this big for shipping. Let me think about it while I'm on vacation next week. I'll be close to the same field of standing dead, so I'll chop a few more down while I'm there.
If I were to make up a batch of five or so hiking sticks, it would greatly reduce the time on each stick. A lot of the time is prep and cleaning up after myself, over the course of a week's work. I could probably get the total working time per stick down to about 5 hours if I do things in batches. This doesn’t include the initial tree selection and cutting it down. Add on about $10.00 worth of materials. Would $100.00 plus packaging and shipping sound right? If that sounds right, I’ll consider doing up a batch of five and trying to sell the others.
I do need some information though. I need to know the height of your elbow from the ground, wearing whatever shoes you normally wear when hiking. I’ll make that measurement towards the bottom of the handle. I also need to know the distance between the tips of your index fingers, with your arms spread straight out. I use this as a length measurement for the entire hiking stick. I find this measurement a little more useful than just your total height.
Hmmm…… Maybe I’ll be able to afford that TOPS Overlander after all.
Tell you, in my view anyone who can make a fine hiking stick and select a TOPS Overland then join them together in the wilderness is a true "Renaissance Man." :eek:
Please check your email concerning the hiking staff, I'll check my measurements and get back to your email.
I am looking at the Overland also. Great design. Great company. For what it is worth, I have several TOPS knives, each for a different purpose, and I USE them every chance I get. 100% satified.
Thank you for considering the request...catch you at the email
Great post. I especially like the look of the grain on the top of the stick-- looks like it feels really nice in the hand. The braiding and handle wrap are neat too. Got me thinking that a Strider-style wrap might look pretty cool over wood. I think I need to head to the woods...
--Josh
Well……. I had a couple of hiking trips this summer, and got a chance to test out my first hiking stick design. It worked well, but definitely needed a few improvements. So I dug out my knives and sandpaper, once again, and attempted to work out the bugs.
First off, there was far too much bend on my first walking stick. The extreme bend in the stick caused slippage as I walking the stick beside me. This small problem was greatly exaggerated on hard surfaces, where the tip of the stick had nothing to bite into. So on my second stick, I looked for wood that was much straighter. After thinking about it, and knowing how a walking stick lanyard works, I understood that the lanyard is the actual pivot point. As long as the upper half of the stick is sufficiently heavy in comparison to the lower half, the hiking stick should pivot correctly. This theory was proven true after a day hike with my improved stick.
Second, the paracord used to wrap the first stick was very rough on the hands and wrist. It held up well, but was just too uncomfortable to use. I decided to go with a complete rawhide wrap and braid on the second stick, using alternating colors. The comfort value of the second stick improved dramatically with the change. I did get some dents on my hand from the lanyard of the second stick, but there was little to no actual chaffing of the skin after extended use.
I also had some issues with the copper tip I used on the first stick. The copper did fine, but the tip was a little too big. The large 7/8 inch tip just didn’t grab into the ground well enough, often sliding when I needed traction. I opted for a smaller ½ inch tip on the second stick. The ½ inch tip worked up out very well, making a much bigger difference than I had anticipated. The smaller tip grabbed well into dirt and general undercover, and slipped easily between the various snarls of roots on older Adirondack trails.
BladeForums own FF also had a nice suggestion. I originally just pressure fitted the copper cap onto the tip of the stick. FF wondered if the tip might loosen up with lowering levels of humidity. I never noticed a problem with the pressure fitting, but decided not to take any chances. I drilled a hole into the second stick’s copper cap, and ran a wood screw through the cap into the tip of the stick. And just to keep moisture from getting in through the screw hole, I placed a Teflon washer between the wood and inside of the cap. This setup lets me remove the cap should I ever wish to strip down and revarnish the stick. I’m not quite sure yet how I feel about this change. FFs” suggestion of just using epoxy to glue the cap to the stick may be better. Time will tell. Affixing the cap to the tip of the hiking stick also allows me to place a rubber furniture leg tip over the end of the stick, without fear of pulling off the copper cap under suction. I did have this problem once with the simple pressure fitting. While I’ve never been a big proponent of rubber tips, they do come in awfully handy on some surfaces. Some more testing needs to done on this issue, or some better ideas need to be thought of. The screw idea seems to work well enough, but it’s pretty ugly.
The rest of the original stick’s design worked out very well. White cedar turned out to be a great choice of wood. The lightness of the cedar was a highly noticeable improvement after just the first mile of travel. The 440 spar varnish also worked out nicely. It took a pretty good beating, and proved itself to be highly waterproof.
The only other significant change to the second hiking stick was the color of stain. I opted to use Early American colored Minwax stain on the second stick. This color of this stain is much darker, providing an exaggerated amount of contrast between grains. While passers by paid compliments to the first stick, the second stick was huge success in the area of appeal. Many other hikers when using the second stick approached me, asking whether I had others for sale. Unfortunately for them and myself, I still considered the stick in the prototype stages, having no others made. I may just have to keep a couple extra sticks in the truck from now on. :)
Well there you have it; months of design and testing, and a good stick to show for it. It may not sound like much, but a good hiking stick is worth a million bucks when ten miles into an extended hike up an Adirondack mountain.
Ahhhh, Buzzbait....you have raised the bar on hicking stick technology!! Like a proven knife, I love a creation that has received the best efforts of its creator, especially when tested in the field and "tweeked" towards perfection. Your hiking aid is smart, classy, functional and yes...beautiful. For me it begs for memories. I know mine will soon be on its way to me, and rest assured it will start collecing memories almost immediately. Thank you.
Very nice stick, Buzzbait! Very pretty and from the description, it seems to work very well for you. I'm sure other people will have different ideas of what works well for them, but the most important thing is that this works well for you.
Could you give us a little better idea of the dimensions of the stick? Perhaps the best would be relative to your own dimensions, e.g., height of stick = chin (or eyebrows, or ...) height of wrap = elbow (i.e., such that your forearm is level, or armpit height or ...). How thick is your stick at the wrap, at the top, at the bottom (takes a 1/2" copper pipe nipple).
All in all, it looks good, obviously feels good and it's always very satisfying to carry such nice workmanship.:)
Good work!
Paul
Here are the basic dimensions of the stick. The stick itself runs two inches shorter than my height. I actually based the length on what was comfortable to carry, with the stick placed over my shoulders, and my fingers gripping it at each end. I like hold the stick this way when I'm not moving, stretching out my arms and hands a bit. The center of the grip is placed so that my arm, when bent at a 90 degree angle at the elbow, grips it nicely.
Thanks! I plan to print out the whole thread.
Amen!:)
Paul
haha! i thought i was the only one that wrapped a handle on my walkinng stick like that! of course mine is much more sloppily done, but...
I have made quite a few sticks in my life but they tend towards function rather than beauty. The one I use and have used primarily for the past 18 years is a 6 foot ironwood branch I skinned it with a large knife ( about a 12 inch bladed cabbage knife) and sanded it with sandstones to a nice finish I then used linseed oil, oxblood bootstain, and silicon waterproofing on it It has prooved indesrtuctable, and has bee used in hiking as an anchor point for a rope when going up steep slopes, and a briar beater for thorny spots, an aid for balance, a path maker in black berry thickets, and a sparring weapon against other staffs and blunt steel swords. I truly love this piece of wood and when/if it ever breaks I will have to find/make another like it. i also have a white oak staff with a nylon rope wrapped handle which has procen itself over 10 years it is much shorter with a crooked top. Staves are a lot of fun to make and not hard to do even with a knive and some sandstone so make one for yourself and play with it.
It is indeed quite hard to choose a particular type of wood to start with. There are just so many different kinds of trees, with so many different properties. I really like cedar. It isn’t nearly as tough as ironwood, but it’s super light. The whole weight thing is a big deal to me. Nothing ticks me off more than lugging around a heavy stick when I hit a straight and flat area of land. If I know that the flat spot will go on for a while, I always end up chucking the heavy stick. It drives me crazy!!!!! :mad:
Then again........ sparring with another stick sounds like a lot of fun. ;)
sparring is fun but dangerous as staves are capable of killing with a single strike gone wrong. as to extra weight I dont' notice it much and on long flat areas I grip the middle of the staff and use it as a pendelum as I walk
