Himalayan Imports, khuks and swords; wetterlings axe; leatherman kicks; crkt m1
Last Visible Canary
actively parsing hurf durf
Himalayan imports:
3rd party customized uddha sword w/gaurd- 110$SOLD
katana - 150$ SOLD
25" siru - 60$ SOLD
18" d-gaurd - 90$SOLD
18" kobra -55$ SOLD
wetterling chopping axe - 40$SOLD
leatherman kick in package - 20$[/B]
leatherman kick in package - 20$ WITHDRAWN
leatherman kick in sheath - 12$ SOLD
crkt m1 - 25$ SOLD
You can email me at SethMurdoc (at) hotmail.com or sethmurdoc (at) comcast.net. I'll be sending this via usps priority mail - all prices are "shipping included". Thanks for looking :D
Pictures can be found at -
http://www.flickr.com/photos/8892472@N03/?saved=1
Edit to add: I do not ship outside of the united states. sorry about the confusion :(
This has had a gaurd made for it, and has had the original antler slabs 2 ton epoxied back into place, with brass threaded bolts as fasteners. I shaved the handle slabs down so that there is a palm swell that is 4 1/2" around, rather then tapering from a thin front to a thick back. The gaurds hole isn't long enough to allow the blade to slip through (the edge actually touches the end of the gaurd when pulled all the way forward), so even if the epoxy thats holding it on were to fail completely, the gaurd would still keep your fingers off the edge. It's not particularly pretty work, but its completely functinoal. the temper goes all the way to the edge, and you can see the hamon line if you hold it right. It has been patina'd and has more of a satin finish now then mirror.
23 3/8" long
17" cutting edge
3/8" thick
handle circumfrances -
3 7/8" at brass
4 1/2" at center
4" at pinky groove
2lbs 2.4oz
made by cresent moon kami
katana -
The handle on this could probably use some work. The tang has been peened to get the pommel brass to be tright against the horn, but in the process the pommell cap caged in a little. The horn also chipped in one place, and has a hairline visible crack running up it. It isn't completely cracked, nor does it appear to be all that bad, but it could definitely use some work. If you drilled a hole at the end of the crack, filled it with super glue, and sanded it down I'm sure it would be completely stable.
36 5/16" long
25 1/2" cutting edge length
5/32" thick
2lb 3.2oz
25" siru -
the temper goes all the way to the edge, and you can see the hamon line if you hold it right. It has been patina'd and has more of a satin finish now then mirror. otherwise its in unused condition
28 1/4" long
18" cutting edge length
3/16" thick
2lb 3.4oz
made by rising sun cami
18" d-gaurd -
I bleached the antler handles, and sanded them down so that the circumfrance was constant for the held portion, rather then taping from thin at the front to thick at the back. when I received it it was much much to wide to hold safely. The tang has been hammered before in order to tighten it up with the gaurd so that it didn't rattle. It recieved a few hammer dings at the pommel from this. the temper goes all the way to the edge, and you can see the hamon line if you hold it right. It has been patina'd and has more of a satin finish now then mirror.
18 9/16" long (diagonally)
11 3/4" cutting edge
3/8" thick
4" handle circumfrance for 3 3/4" after front gaurd
2lb 4.6oz
made by rising sun kami
18" kobra -
18 3/8" long
11 3/4" cutting edge length
3/8" thick
1lb 4.7oz
This has never been used for anything. it does have some light surface rust on the forge patina'd portion of the head. I'm not going to sand this off before selling it, so as to keep its appearence essentially as it was recieved.
5" cutting edge length
31 1/2" long
4lb 4.4oz
as described by ragnar (from ragnar weed forge): "#Wett32; The Chopping Axe is a full sized felling axe. The handle is about 31" long, and the head is about 7 3/4" wide with a 4" cutting edge. Nominal weight of the head is 3 pounds, (1.4kg), and sample axes weighed a bit over 4 1/2 pounds."
I got it as a companion for my gransfors bruks american felling axe, wich is considerably thinner in overal geometry. This axe would do much better at splitting tasks.
new in package.
I've caried this a few times, but its in like new condition. comes with leather sheath.
crkt m1 -
I've used this for cutting open packages, and nothing else. It's not pristeen, but its in very good condition. The edge is very asymettrical, where as some of the m1's are much closer to a perfect v cutting edge. this one is so assymetrical that the more acute taller cutting edge bevel actually has a pronounced visible hollow grind to it.
Seth,
As always, you and my wallet will likely do the slow dance. Anyway, I'll e-mail you on the Uddha and Katana when I get to work in a couple of hours.
I'm not sure wether the 72 hour bump rule is in regards to the last post made by any member, or the last post made by the seller....
Price drops on d-gaurd, uddha and axe
edit to add: thanks, good to know :) (and sorry)
It's 72 hours from the last post, period...It don't matter if the last post was by the author of the thread, someone else, or god.:D.
more price drops... I really need the money right now....
[edit to add: it was pointed out to me that my price was high for the comparable dimentioned wetterlings model, and I realized that I was looking at gransfors models when I came upon the model name and price. in reality I now beleive that this is the wetterlings chopping model, and my other axe that I'm keeping is the "gransfors american felling" model.
as such, the price has been reduced to 55$. keep in mind that this is the shipped price, so you are saving on shipping as compared to other websites that have similar prices.]
yes I do take money orders, but I will only ship upon receiving them. checks will have to clear first before the packages are shipped.
I am sorry, I am going to pass on the kick. Not for the reason of you shipping upon receiving the MO, but I am a little tight on cash right now. If they are still for sale when i get more money, I will probably buy one.
Just wanted to let everyone know that Josh is great to deal with - I got the Udda sword today and the whole process couldn't have gone smoother. Josh was great at communication, shipped quickly and packaged securely. The sword itself was exactly as advertised - but better. Thanks Josh.
Same here, the original Kick was lost by the USPS, and he sent me another with FedEx. Very understanding, thanks again.
Interested in the axe. How is the head/handle alignment? I have heard that some Wetterlings can be a bit askew. Thanks!
