Hinderer XM-18, gen 3 to gen 4 conversion
REK Knives
Moderator
I have never understood Rick's decision to go with the stop pin placement on the gen 3 models. After several sharpenings, the blade becomes almost useless w/ detent slop.
With that in mind, I got a flipperless gen 3 (or earlier) XM-18 in for a regrind. I did not feel comfortable doing a regrind on this particular blade because it wouldn't have taken much for the blade to develop detent play, so since my customer was up for it and I was as well, I set in for a stop pin placement change!
Had to do some grinding on the blade tang itself for fitting, but turned out perfect.
Then I was able to knock the grind out w/ no fear! :)
Good job... and you're right, I hadn't seen that before, but judging from your picture, that Gen 3 was a bad idea.
Fantastic work Josh, both the regrind and the stop pin conversion. I guess that is an advantage of the blade mounted stop pin/thumb lugs - no worries about lockup timing being altered.
Thanks dude!
The pin placement actually doesn't touch the blade tang, but is a close "backup" for it - the double lugs provide the stop when the blade opens, the pin provides the stop when it closes.
That is one nice regrind. I've been contemplating on that for my spanto as it is a little thicker than I like. Is the blade polished where the washers rest against it.
